Results 1 to 4 of 4
Swapping the frame on an '05 SV650...
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Never laid hands on an SV until I picked up this wreck a few months back:
    I'm replacing the frame, front end, exhaust, rad, and some other bits. So basically full disassembly and then rebuild around the new frame.
    Any tips/tricks on supporting the frame while removing and then installing the engine? I was thinking something along the lines of removing the donor rear, installing on the new frame along with the new front end, then I can support with stands to do the engine swap. But then I can't keep the rear up on the donor. Jacks under the frame sliders might work for both frames, but pretty sure the bolts pass through the frame & engine.
    Other thought is supporting everything on the engine with a hydraulic car jack - dicey but possible.
    I don't have overhead beams that I would trust with the weight, and not too keen on the ladder trick.
    Obviously I haven't thought this through which is why I'm asking - anyone gone through this with any wisdom to share?
    Pretty sure I have the special tools needed. Trying to be prepared for this project instead of placing 73 small orders over 10 months.
    Should be an afternoon job right?
    05GSXR75005SV65090DR350
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: Swapping the frame on an '05 SV650...
    jack stands on the foot pegs
    Front stand under the triple
    scissor stand to lower the motor
    If I can drop/reinstall a GSXR750 motor myself using a couple hydraulic car jacks and front/rear stands, I'm sure you can too. Just use some wood to make a "cradle" for the engine so you aren't putting a ton of weight on the oil pan or any other one location via a hard metal jack pad.
    Mar 2016
    Falmouth, ME
    Cool, thanks! Yeah, I'm not too worried about pulling it off just want to minimize cursing and wrench throwing and such things.
  1. For Sale - Parts & Tools | SV650 Frame
    By Dayon in forum For Sale
    Last Post: 06-05-19, 06:33 PM
  2. For Sale - Parts & Tools | First gen sv650 frame
    By theducman in forum For Sale
    Last Post: 04-15-18, 04:58 PM
  3. For Sale - Parts & Tools | WTB: 2nd gen sv650 frame with title
    By juha_teuvonnen in forum For Sale
    Last Post: 08-15-15, 09:23 AM
  4. Swapping frame, how to register new VIN?
    By island boyeee in forum General Bike Related
    Last Post: 12-04-14, 09:43 AM
  5. sv650 frame sliders
    By Loun in forum Pit Area
    Last Post: 06-06-08, 09:26 AM
