I'm helping a friend swap out is blown motor from hiw 04 gsxr600 and putting in an 05 gsxr750 motor. This is one of those "direct swaps" you read about on the innerweb
Everything is pretty much done, when you turn the bike on it goes through all the "checks", the LCD screen doesn't spit out any errors or nuttin... When we try to start it the motor turns over but does not fire then eventually spits out the "FI" code on the LCD screen. There is a PCIII in the mix and for some reason my laptop does says it is not communicating with the PCIII but picks up the S/N of the unit and registers throttle position. It also picks up "something" when we tried starting it with it conencted but then returns to "not communicating"
It was getting late so other then a quick check of the connections we really didnt get into further..
possible problems:
-bad wiring connection - ground or a bad "clip" connection
-bad ECU - he bought this on ebay, 750 ECU needed for swap
-bad tip over or kickstand sensor - will the motor turn over if these are bad?
any tips from the "pros" would be greatly appriciated before we start troubleshooting.....thanks![]()
Red -
I know with the 06/07's the FI light comes on frequently and can be resolved by disabling the set valve -
hope this helps your buddy
fi light with set valve removal - Gixxer.com
Ground power commander to battery.
if no start, then try removing power commander from the loop.
derek
Sounds like it's definitely electronic in nature. There's not much reason why a fuse should have blown, so kinda put that to the back of your mind. Think about ECU (reseat the connection and check for bent pins).
How many times does the fi light flash? That's usually a code for what sensor is down.
derek
Oops, forgot. The gixxas need to be in dealer mode to access the fi codes.
Talked to a contact of mine, he says set valve is the first thing to check.
Ryan, you're good with a soldering iron here's how you wire yourself a dealer mode switch and save the $60 diagnostic fee at the stealership.
degs
the power commander issue is normal, on your year model it wont communicate until its running, if you toggle the kill switch from off to on with your cpu connected it will communicate while the fuel pump activates but will shut off when the pump stops. So you only problem is the no start, which is due to 600 and 750 ecu's being different. Get the 750 ecu and you should be good to go, remember the bike must be running on this model to upload your map. You are using the 600 ecu but the 750 motor correct?
That means you dont have a 750 ecu or do you think you have a bad 750 ecu? Just want to be clear on your situation so my info will be accurate. If you already have the 750 ecu let me know we'll go from there.
Is the fuel pump priming?
Ok, thats a bit more difficult. There is no good way to test an ecu other that swapping it to another 04/05 750. Buying used electrical parts is a crap shoot. Other things to check, the ground strap to the back of the motor is tight and good connection, all vacuum lines, especially the atmospheric pressure sensor. I assume youve already checked that all your connectors go to the right spots, more importantly coil and fuel injector connectores as they are interchangable. What about coils, those are different between the two models and will definately give you problems being there are resistance differences. All depending if the resistance is higher or lower you can do no damage or fry your ecu.
Dont worry about the kickstand switch, will cause engine to not turn over.
I had the same problem on my 954 with the pcIII, it would read serial # but that was it. it wasnt getting power, are you sure youre gettin 12v in the PCIII? The guys at dynojet were semmed to know their stuff when I called em, pretty helpful too.
So you are using coils from a 750?
I also believe the power commander for the 600 and 750 are different.
Let me know if you checked the things I mentioned, inquiring minds want to know! Before you try to diagnose failures or mistakes made in any kind of motor swap you have to start with confirming what parts are the same and whats different between the two or youll end up hanging yourself.
The PC3 should have come with an adapter that'll let you plug a 9v battery direct into it. Don't ask why, but on many bikes they won't talk to your laptop with the bike on unless it's running or that battery is connected.
For now though, unplug the PC3, and eliminate that potential issue from the loop. Get the motor to fire on the stock ECU before you try and tune it.
Have you pulled a plug and verified you're getting spark?
