identify this plug.
It's something to do with my headlights, but I can't seem to find it in my service manual.
I'd really like to know what each wire is for, as I'm having issues with my low-beam.
it's on the right side fairing.
middle plug is the directional, bottom plug is the main wire harness plug I think.
not sure what that is, but I'll help you trouble-shoot if you want. we can also check it out on Pat's bike
08 Triumph Daytona 675, Jet Black w/ Gold
dirty bike: 2015 KTM 250 XC-F
ok. I just looked all through the manual and couldn't find anything either
Have you looked for a wiring diagram? That will tell you what that plug is for based on the wire colors.
2023 KTM 890 Adventure R
'06 Triumph Sprint ST ABS
'90 Yamaha XT350
on top of what Jim said, i looked specifically for a color-coded wiring diagram, but there isn't one in the manual. i was going to attempt to trace every wire by color
What year gsxr is it? I looked at the diagram for the 2010 600 and couldn't find a white with green stripe or white with blue stripe, so I hope that isn't the bike.
'90 Yamaha XT350
page 348 is the closest thing to any kind of help, but i can't make sense of it based on the wire colors at that switch. if i saw it in person i'm sure i could trace it.
yea, you said right side above..? that's what i looked at. besides, you can tell just by looking at the picture
I don't know the model years in relation to the "K" designation, but this is the wiring diagram for a K2:
http://www.gixxer.com/photopost/data...ng_Diagram.jpg
I found that too and looked at it a few times, but couldn't match the wires up
K1 = 2001
K2 = 2002
etc
The only wires I could match up were ones that didn't make a whole lot of sense.
White w/blue stripe = cylinder one coil/spark plug
Red w/purple stripe = fuel pump
Can't find white w/green stripe anywhere, can't easily identify the others to look.
'90 Yamaha XT350
I see a about 16 wires coming through both of those connectors, and if you look at the wiring diagram, there are 16 wires coming through 2 separate connectors just below the cluster. I believe those are your connections, and maybe there are some wire color differences between years.
yes Kx = 200x
2001-2003 600cc = 2000-2003 750cc = 2001-2002 1000cc
oh i gotcha Jim. yea i'm smarter than the average computer tech
not sure when i can get Pat to let me look at that, since he just got everything painted and put it on, but i'll see what i can do. if you want to take it apart again some evening, let me know
'90 Yamaha XT350
Jim, is it possible that got replaced when the previous owner switched the headlight assembly?? it doesn't look like it, but...
