What are you guys using instead of Dzus? I don't like the quarter turn, I want something that actually threads in. My bodywork isn't that great, doesn't line up perfectly, and the lower mounts to the upper in a very narrow spot so there is only room for 2 fasteners instead of the standard 3. I want those 2 fasteners to be SECURE. Right now I've solved that by ziptieing or safety wiring the dzus clips to one another.
I'm fed up with it to the point that I'm considering just buying new body work...but mine really isn't terrible and I'd rather spend that money on a million other things.
I want to rivet the base clip to the upper body work, I do not want a "clip-on" style fastener.
Is there something out there? I swear I've seen them before.
Thanks folks.
I use rivet base d-zuzs, you can get rivet on 'anchor nut' plates that will take full threaded fasteners. Bear in mind you'll need to bush the screws so they never actually compress the glass bodywork or it'll crumble in short order. Metric Self-Locking Nut Plate, Floating | Pegasus
Edit: You can adjust the tension on the D-zuzs fasteners too fyi, either by tweaking the clip or playing with teflon shim washers.
Check speedyfasteners.com, they have a bunch of options. For some reason it's being blocked for me at work for malware or something at the moment though.
Look up "speed nut clip"
Yesssss that's what I want. Maybe I just bought cheap Dzus, but they never worked great from the start and have gotten significantly worse over time.
Blocked for me as well
Not sure I can safely google that at work without getting fired.
Self Retaining Speed Nuts | Self Retainers & Spring Clips - Bolt Products, Inc. - Bolt Products Inc.
