I can play a video, with the GPS data displayed, but I usually start the GoPro in the pit, then the Qstarz at the start/finish line.
So they're several minutes out of sync. It seems like it should be pretty easy to set a common starting point for each, but there doesn't seem to be an easy way to do it. It also only seems to match up the video one lap at a time. Am I doing something wrong?
Not to mention that Q-Racing seems to be a bit buggy.
LRRS 919
Once you have selected the Lap, click the "Set Video for Track" icon on the top of the screen. Click the "Add" icon to down load the video, then click the video file and select "edit". A "Set Video Time for Track" screen will appear. Hit play and pause the video at the Start/Finish Line. Click "Ok" and the video is synced to the Start/Finish. If your grid position is a second wave or deep into the field, there may be some slight editing required. The best edit tool is to watch the video into T1 and compare the apex point on the video to the Speed/Distance Graph at the bottom of the QStarz. If they match, then the rest of the lap data/video is synced correctly. See my video at https://www.youtube.com/watch?v=2LRcvYiRFOE
