Results 1 to 25 of 33
Toggle Switch instead of key-ignition
    Looking to switch my ignition to a toggle switch now that i switched front ends on my R6 and the initial ignition key and everything dont line up. Does anyone know if i need a certain type of toggle switch? I've read up and know how to do the wiring. Just curious what others have used as a toggle that has worked well for them.
    Thanks!
    Lifer ilikenapalm's Avatar
    Connecticut
    Re: Toggle Switch instead of key-ignition
    I bookmarked this in case I ever had something similar come up... maybe it'll help you out?
    http://www.customfighters.com/forums...ad.php?t=40232
    If you're going to just do a toggle, toss it under the seat kinda tucked away so only you know where it is.
    Toggle Switch instead of key-ignition-20140316_131454-jpg
    That's the ignition on my SV track toy. Just a standard, off the shelf SPST switch. Nothing special as far as I can tell.
    With the SV there is a very optimized wiring diagram floating around for track day and race-bike setup. Maybe look for something similar?
    Senior Member WinVT's Avatar
    Winooski VT
    I can post a picture of mine tomorrow night
    LRRS #313
    Thanks for this post! I did this mod over the weekend and it came out awesome. As was said by others 1" PVC works for the 06-07 models. There was no way I was getting the 1-1/4" in there. I used a 15A illuminated rocker switch and painted the PVC with undercoating to give it a black rubbery finish.
    Also to note: to remove the ignition I ground slots in the headless bolts with my dremel and cutoff wheel. Then I used an impact driver while holding the triple with a vice and rags. They came out easily and it was much easier than drilling.
    Again thanks for the tutorial!
    This was my post on the r6 forum showing my results of my keyless ignition on my 06 R6.
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    Here's my set up. Shaved the ignition loop and used angle aluminum to mount the switches.
    Durham
    Anything in the drawers at radio shack will work. Which one to use is entirely up to your personal preference. I prefer rocker switches to toggles because they're less likely to get bumped inadvertently turning the bike on or off when it isn't intended.
    at one point i had my ignition hooked up to the kill switch. flip the kill switch on and the bike comes on.
    when it didnt work i put it all back to stock and then realized it still didnt work. thats when i found a broken wire. at that point i had chased the broken wire for an hour and didnt feel like going back to the kill switch ignition. it was pretty easy though
    May 2010
    Somersworth, NH
    dont think i could ever go keyless on my streetbike... the SV track bike tho is wired up keyless off of the kill switch and its really nice not having to worry about losing the key at the track or in transit
    Nov 2007
    I went keyless on my R6 race bike. The only thing I would note is to buy a waterproof switch, like from a marine/boat supply company.
    One time I trailered up in light rain and then put my bike in the garage. The next morning my battery was dead. Water had gotten in the switch and shorted it out, causing the ignition to turn on and off all night. I blew it out with compressed air and it was fine, and ziptied a rag around the triple for the ride home. Luckily I didn't learn any of this on track during a rain race or something.
    Later I got the correct switch, only like 8 bucks.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    What type of bike? Some, like the SV650, have a resistor built into the ignition switch, which prevents the bike from being started, if removed. You have to put a resistor in-line. That said, here's the switch I installed on my 99 SV:
    I found it by Googling for "water resistant rocker switch". It's basically a marine switch.
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    Mine is on my left clip on: Toggle Switch instead of key-ignition-uploadfromtaptalk1402062993111-jpg
    Yes, my tach is broken in this pic.
    Posting Freak Gecko's Avatar
    Jul 2008
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    thank you all for the responses! i like the idea of the boat switch as ive been caught in some light rain during track days here and there. the bike is a 99 r6, i've read up and it doesnt have all those resistor and other wiring issues you have to worry about with the sv650's.
    I would most certainly place your switch exactly where bubba put his. That way on the first low side, all of your wires are trashed & you're done riding for the day....possibly weekend.
    Ha. I didn't put that switch there. One of you LRRS knuckle heads did.. then you raced the piss out of the bike, crashed it 12 ways 'til Sunday, then sold it to someone who sold it to me. First thing I did is take it out in the rain @ a Penguin track day and high-side it. Later I low-sided it.. right onto that side.
    Ignition switch has never given me any trouble.
    The problem with the switch in that position is you have to find neutral before reaching down to turn the bike off. Or reach across the tank. It is awkward. But I certainly do not worry about it ruining my weekend.
    Sep 2011
    Peabody, Ma
    I keep thinking of doing the RFID ignition on my bike... Maybe one day I will.
    07 S4RS
    Just get one from Street & Comp. Took me longer to make the wiring pretty, then actually install it.
    Toggle Switch instead of key-ignition-imageuploadedbytapatalk1402231826-534621-jpg
    Lifer Pittenger5's Avatar
    Austin
    Anyone know of a good write up with pictures? I hate electrical.
    Zip Tie Alley #505
    My picture above is self explanatory. Plugged into my factory harness.
    May 2013
    Epsom, NH
    Do you remember what resistance you needed? I was thinking of doing same with my SV.
    1st or 2nd gen?
    Here's a useful thread. http://www.svrider.com/forum/showthr...yless+ignition
    May 2013
    Epsom, NH
    Smile Re: Toggle Switch instead of key-ignition
    1st or 2nd gen?
    1st Gen. Thanks for the link oreo!
    Austin
    So if the switch has 3 connectors, but my ignition only had 2 wires, what do I do?
    Zip Tie Alley #505
    Use two of them.
  1. any one have a ignition box
    By lrrs428 in forum General Bike Related
    Last Post: 06-10-09, 04:28 PM
  2. PITA ignition switch.
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-21-09, 07:45 AM
  3. Replacing ignition key/switch?
    Last Post: 01-15-09, 03:50 PM
  4. Ignition?
    By Murphy_101 in forum General Bike Related
    Last Post: 05-22-07, 07:18 PM
  5. Kickstand Switch for ignition kill
    Last Post: 06-30-04, 09:09 PM
