I'm looking at purchasing a high mileage 2004 FJR1300. It has 116,000 plus on the clock. From the pictures, it looks meticulously maintained. It comes with an extra Yamaha top box as well, which is nice.The owner says he has been good with maintenance, including valve train refresh at 100k miles, i.e. cam chan replacement, valve check etc.
I have heard about the legendary reliability about these bikes. Are there any owners on here who can speak to common issues, or what to look for?
Sent from my SM-G965U1 using Tapatalk
Common issues for the first couple model years were with the valve train however, Yamaha would never admit to it.
I don't recall the specific details but it was something about the machining angle of the valve guides and valves not closing into the seats properly. The engines would emit a ticking noise that sounded a bit like a worn cam chain tensioner.
I'd guess at those miles, it's likely not an issue. Otherwise a bulletproof machine. Wish I held onto my 2005 and simply replaced the shock.
how much is a bike with 116k miles even worth?
This was listed under NSFW... Not sure if I am disappointed or relieved that this is very much a work-safe post.
I would assume the suspension is LOOOOOOOOOOOONG past due for maint, might be easier to throw a shock and linkage bearings at it out of the crate than trying to revive what's there?
Yep, that's the price range of this one.
Yep, I have no idea why it got labeled this way. Maybe its warning me about a bike with this many miles
I'm not sure of the status of the suspension. The bike is really clean (see attached pic). Its a valid concern though, and I should ask the seller.
EDIT: The seller states that he has recently had the suspensions serviced.
fuck it
run it
Damn dude. If you buy that thing make sure you save some pussy for the rest of us.
The couple things I'd recommend checking are how creative the previous owner got with electrical "enhancements" and has anything made a home in the air filter box or under the seat. I don't recall them changing much over the years.
The FJR I had didn't have a serviceable rear shock. That's always been the weak link of that bike, the rear shock. Kind of soft, I like many always ran the rear shock in two up setting to increase the stiffness. If this guy drove mostly one up, he wasn't taxing that engine. Even when I was loaded with camping gear, running that engine hard meant getting into "go directly to jail" numbers easily. I don't know what the service life of those engines is, but I would expect with 116k on the clock she's got a few left in her.
