Results 1 to 20 of 20
$5 "Wood"craft rear bike stand
    WMC original sdog30's Avatar
    Burgy
    Soooo, needed to change my rear sprocket and couldn't wait for the rear stand, so fabbed one up myself. (Did I mention I'm a carpenter by trade?)
    LRRS/CCS #66
    Burgy
    Re: $5 "Wood"craft rear bike stand
    I had to make a few adjustments...I forgot to stabilize it length wise, so it was a little rocky. Who says you need to spend $150 on a rear stand??
    But seriously, I'm ordering a Vortex next week. Just needed something in a pinch and thought you guys might get a kick out of it.
    LRRS/CCS #66
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    How much are the plans?
    Apr 2008
    Boston, MA
    nudge
    Burgy
    PLANS?!?
    You don't need no stinkin' plans. Buy a 2x4, cut the base so it's wide enough to fit the pieces, cut the height a couple inches higher than height of the rear, cut the side supports at 45°, screw everything together, done. Took me about 15 minutes (maybe 20, I'm anal retentive).
    LRRS/CCS #66
    Aug 2009
    Hillsborough County, NH
    What was the procedure to get the bike up onto the stand??
    Nov 2008
    Framingham, MA
    Quote Originally Posted by Trajiks9 View Post
    I was wondering the same thing.
    The stand if very ingenuous. Good job.
    Apr 2006
    Beverly, MA
    I like what you've done there. If only I had the skills to "mickey mouse" stuff that well.
    Burgy
    This will probably sound crazy, but I leave the bike in neutral and roll it back toward the stand, then lift the rear end by the subframe under the seat and set it on to the stand. I have to move the stand a little in to place with my foot.
    It's not as easy of a set up as using the leverage of the stand with wheels to lift the bike, but it worked in a pinch. Thank god I didn't have to lift the front. The rear is so much easier to lift than front.
    LRRS/CCS #66
    Southern, NH
    wow that looks solid
    Central MA
    Dood, in the first post, it looked as though you had used a lead anchor and bolted the stand to the sidewalk!
    Greybeard Just_Jeff's Avatar
    Amston CT
    anything that works is good, no matter what it looks like., not that it looks bad.. just sayin
    1967 Model Human, All male accessories. Manufactured by John & Irene
    Burgy
    I see what you're talking about, that's the collar that goes on the right side of the axle between the bearings and the caliper.
    If you notice in the second set of pictures, there's a brace I added to the front and back to make it more stable. When I originally built it, all I was thinking was side to side, but found out I had to keep an eye on movement front to back, especially when trying to put the wheel back on. Had a few close calls.
    Thanks everybody. I really just posted it as a joke. I mean, I really did build and use it, but it's not ideal by any means.
    LRRS/CCS #66
    Burgy
    The funny part about this whole thing was I needed to change the rear sprocket. I had a Vortex on and just stripped all the teeth off last week. I have a parts bike that I took the rear sprocket off, but didn't realize until I had it mounted on the wheel and was going to put it back on that it was for a different sized chain.
    I was trying to match a 520 chain to a 525 or 530 sprocket. Lesson is - check to make sure the used sprocket that you take off your parts bike to get you through the rest of the season until you can afford to buy a nice DID/Stealth replacement is the right size before you go through the effort of building a rear stand and have your bike half apart. (long lesson, I know)
    LRRS/CCS #66
    Senior Member spydah's Avatar
    Fitchburg, MA
    Can you make one for my car
    LRRS #831 Novice
    2007 Ducati 1098 - Street (okay, sometimes track)
    2002 Suzuki sv650 - Pure track!
    2007 Suzuki sv650 - Next seasons track bike
    http://www.myspace.com/spydah77
    Quote Originally Posted by spydah View Post
    Sure, I'll get the 4x4's, you lift the car....
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Just dont keep them outside , should have used pressure treated...Kidding bud, but seriously nice quick idea..
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    I think I need you to make me an m/c lift
    pronto!!
    Q
    Senior Member btr_ftw's Avatar
    Salem, MA
    clever! I may have to do this
    Massachusetts' Noth Shoah
    Here's mine!
    Go fast. Have fun. Repeat.
  1. Wood craft rear seat foot peg for this weekend
    By k1200s in forum General Track Day Talk
    Last Post: 05-17-18, 03:15 PM
  2. Wanted - Parts & Tools | Pitbull Front Stand Pin "Standard Size"
    By island boyeee in forum Wanted
    Last Post: 06-01-15, 03:53 PM
  3. Pit bull rear spool stand, "forward" handle
    By atticdog in forum For Sale
    Last Post: 04-26-12, 06:14 AM
  4. Pit bull rear spool stand, "forward" handle
    By trider143 in forum For Sale
    Last Post: 05-25-11, 06:00 PM
